Forceofaqua
Hello all,
I'm on the last leg of getting my goblin started up, but I'm running into an interesting issue. I simply cannot get any spark on any of the plugs to fire. The coils seem to be ok as I can read a consistent 6v between the inside coil spring and the engine body. (not sure if this is normal. this voltage drops a few digits when cranking). Crank position sensor is plugged in, and worked before taking the cobalt apart. The OBD2 sensor is giving me 6 degrees of timing on Cylinder 1. Are there any other things that I can check?
Donor: 05 SS/SC
Donor: 05 SS/SC
