Rabid Sloth Racing
Hey all,
I'm having some bad power loss issues. The car has always run better with the MAF disconnected but last night it started running really rough. After about an hour of cruising around just fine it started sputtering under WOT and finally died to the point i thought I had run it out of gas. After filling it up it was very hard to start and had a dramatic loss of power anywhere over ~25% throttle. I limped it home and took the video below. the only codes that were thrown were P0443, P0449, P0452, and P0300. As hot as it was I didn't really feel like working on it, so I let it sit overnight. This evening when I went out it was still very hard to start, idled weakly, and was running rough when it did start. I did a quick loop around the block and from idle to ~1750 rpm its rough. then up to any rpm and very little throttle it will move. It I give it much more than ~25% of the pedal it dies again. Tonight there was no P0300 code, but all the others are still there. I tried it with and without the MAF connected with the same results.
I'm hoping someone might have ideas before I start tearing into it.
The fuel filter only has ~50 miles on it. Just put a new MAF in. I went borderline psycho when doing the grounds. From a quicklook I don't see any loose connections...
