Mayor West
For the first time in a few weeks (and since I put Opel Injectors & S2 ZZP cams in) I took the gobo for its first spin.
I have a lil twitchy throttle and torque mgmt ramping to adjust in the tune but it's running very well, no backfires or hesitation. Thanks to @OptimizePrime for helping me by sharing his tune. I'm really glad it's doing well. Alignment is decent enough for 50-60mph but I'm sure it could be fine-tuned with a professional system.
My RMS leak appears to be fixed now (finger's crossed) as well as my water pump cover leak. I do have a very small coolant leak but I can see where it's coming from and it appears to just be a hose that needs tightening. Temps were all under 198 degrees and AIT was 75 degrees or less. It's 69ish outside right now so I'm happy enough with that (I wasn't rompin' on it, just casual driving). I didn't scan for some reason so I don't know about knock or fuel trims or whatever.
Very happy with the fact that I did the cams and timing again without screwing it up... three cheers for me and my wallet.
I'm sad I didn't get to bring it to the NC meet with @OptimizePrime , @Wes , @Rauq , @KSLunsfo , and @baustin last weekend. Next time, I'll be there (unless I blow something up).
I have two months of paternity coming up so I'll have some time to fine tune everything...
Up next on the to-do list:
- Real alignment
- Slight tune adjustments
- Fix my manual steering, it's very loose feeling inside the joints... it vibrates a lot and just isn't that great. I'm considering using the stock DF steering but making an adapter plate to move it more center, as well as removing the power steering part of it.
- Wire dash cam, also move it to another spot because it's mostly useless on the top rack as-is...
- Replace one of the seals in the brake reservoir
- Figure out a better brake light situation, sometimes they just don't work.... that potentiometer mess is garbage.
- Figure out if I want to use my windshield or not.
- Find a neat solution for the side panels, thinking running paracord around everywhere to make it sort semi-solid or something
- Find a neat solution to the roof/sun issue. I like what others have done with tarp-like shades, but I can't sew so I'm not sure I can make it look nice.
