Yeah that's first on my list before removal because I'm fairly certain I tightened that slave side very well.Check the top real well. Mine looked like it was leaking from internal, but it was at that elbow from the line to the slave. That goofy oring can be a pain. The oring needs to be on the slave side, line. Then the elbow goes on (if it’s the same as my supercharged model).
Yeah I made sure I had that. It's hooked up and appears to be tight but it was leaking a lot prior to fixing it (I pressed the clutch a lot out of excitement too) so I'm sure it was full of fluid so I'm hoping the dripping is from residual fluid in there and not new fluid.Odd question: you do have the U looking clip for the elbow correct? And it’s in good shape? I had to “rework” mine to keep it all tight.
Twice now I have sunglasses flew off my head and I had to turn around and go back to get them. Just drove up to them and reached over onto the ground to pick them up. Came in quite handy. It can be a bit intimidating at first.Very happy with it.
It's so small and intimate that close to the road. Can't wait to get it tuned, aligned, and running smooth.
Dude those seats are bad ass!!! Is that denim???Maiden Voyage! Very happy to be at this point. I got into 2nd gear around the neighborhood. It's very loud in my garage but out in the open it's tame enough to not cause too much of a ruckus.
Very happy with it.
- Radiator
Wire to black multiplug- Wire fan
- Wiring
Tidy up unused plugs- Put ambient air sensor somewhere
- Fully implement wideband wiring
- Wire headlights
- Wire mirrors
- Wire brake lights
- Alignment
- Do it
- Tune
- Do it
Install IntakeInstall Side MirrorsRear Brake Calipers
Install calipersInstall Parking Brake AdaptersParking Brake
Install on to shift tunnelBrake Hard Lines
Front lines from main to wheelsBrake Soft Lines
FrontRearBattery Hold Down Bracket
Install/Cut boltsBrake Booster Vacuum Hose
Install Front & RearPrint 2nd adapterFluids
Brake/ClutchRadiator (100% water for now)Bleed
BrakesClutchFuel Tank
Vent Hose NippleSandblast Fuel NeckPaint Fuel NeckInstallEngine Mounts
Paint new solid mountsInstallShift Cables
InstallShift Linkage
Install OTTP with custom made adapters for threaded rodSteering
Figure out adapters/mount for new manual steeringMount new manual steering adapterFind a nut to attach hub adapterTurbo
Install vacuum nipple in compressorHook up vacuum lines to BOV, Wastegate, and boost solenoidBCM
Install Kickplate
**** they look like it!Yeah man, comy AF.
