The MAF should ideally be put in a section of tube that has the best laminar flow. Basically not too close to the filter, near an elbow, or turbo.
Grats!It started! I got my first start! I was pretty nervous to try for it. But it worked out. I will try to get a video out tomorrow.
A set of those came on my donor when I bought it! I would've sold you mine really cheap, but they are all curb'd up...I purchased my wheels (Drag 33) from Discount Tire (https://www.discounttire.com/buy-wheels/drag-dr-33). They were a little confused when I told them I just wanted the tires mounted onto the wheels, but didn't want them installed on the car itself. Took about a week from when I ordered to when I picked them up.
Nice!I just got my Konig Tandem 17x9.5 +15 yesterday. They were supposed to be here in 3 days from LA and got them 12 days later.
They are sitting 3/4" off the spring in the rear.
I'm going to run a narrower non performance tire with fenders to do the registration process and then pull them off to run these for street use.Nice!
Are you planning on running fenders?
My difficulty is that I plan to have fenders and I'm trying to get the offset so that the wheel will line up center to the fender. I can do some adjusting once I have the wheels, but I'd like to get it close to start.
yes, I have the wide fenders.I'm going to run a narrower non performance tire with fenders to do the registration process and then pull them off to run these for street use.
Do you have the fenders?
Well, good luck. Discount and Tire Works were both quick to help, but neither could get the tandem in under 1 mo. The Toyo R1R's were a problem also.yes, I have the wide fenders.
I've measured, doubted measurements, measured again, and repeat. I think I have the right measurements now... just have to find a place that will answer the phone or return emails.
