So I ordered two of these bushing from Amazon for my LNF goblin and got two different color bushing. Gold and silver. They measure out pretty close to the same except the big outside rings is slightly larger on the the gold one. (see first couple of pictures). I dont think it will be an issue, but I contact Amazon to see how I can contact the seller to confirm if they both would work but they where not helpful and only offered refund/discount/replacements. So I decided to see what the replacements would look like. And once again I got one gold and one silver
I held onto the first two, but I need to return them soon though. The gold all look used, you can see scratches on the inner ring like a bolt has been through there.
The Silver all have the MOOG61121100 markings, darker gold has MOOG61120280, lighter gold has MOOG61120340
I was going to use the two silver ones and returning the two gold ones, mostly because the gold ones look installed and removed previously. But I read on here that since these LCA are aluminum the gold plating acts as a barrier to prevent corrosions.?. any truth to that?
Anyone else run into similar issue? If anyone still has a few laying around what part numbers do you have on your bushing, and do you remember if yours was gold or silver?
