ncgoblin
Hey guys I have replaced the passenger tie rod which is a bit larger and longer. The length and size I am not concerned with because now their is more steering arm threaded in. My concern is I received (2) nuts one which is a bit larger size then the threads of the bolt but is required to install the castle nut and slide the cotter pin between the nut and torque to 55 ft pounds. Does this look right to you all? First time I have stacked nuts on a tie-rod due to the overall length of the joint bolt.
or did I receive the wrong part?
