Haha, When it doesn't start now I can blame someone else at least.famous last words there.
Could be worse! LOLShe thinks it's going to be her winery-trip-mobile. Guess I owe her that much for putting up with all my garage time.
oh dang! it just hurts seeing shavings in an intake cover!This is some nerve-wracking work reattaching the valve cover baffles. Self tappers wouldn't eat the metal and two broke off, having to drill n tap. Not sure if the risk and trouble were worth having a flashy cover. Should have just painted it. Plus it's delaying the first start.
I
What do you mean the outside pad is DG1095 they should both be if you have e-brake or just regular cobalt DG956Anyone with solstice rear rotors have problems getting the pads over the rotor on install? I have the piston turned in as far as it will go but the pads just won't clear the rotor. The outside pad (dg1095) is angled from hitting the end of the channel it rides in.
At least I finished the valve cover.
This is the solstice parking brake setup.I thought you only used solstice DG 1095 if you had emergency brake other wise normal DG956
The pad set is DG1095. I was just talking about the outside pad getting hung up there.What do you mean the outside pad is DG1095 they should both be if you have e-brake or just regular cobalt DG956
