If you are not familiar with a catch can, they "catch" all of the suspended oil in the crankcase and valve cover venting. Typically they are vented into the intake so it can be burned, however, the oily air can clog up the intake intercooler laminova tubes and cake the back of the valves in direct injection engines. It's best to get rid of this oil if possible.
I started with a blow-through type and then changed my mind only because of personal preference and went with the vented type. So now I have a like-new catch can that has only about 3 rides on it and not a drop of oil in it. My indecisiveness can be your gain. This Moroso unit alone sells for $160. Pictured below is my NEW setup and not the actual item for sale because I didn't think about actually taking a photo of it before I removed it. But the current set up is almost identical other than it has a breather filter on it and not the extra hose to the intake.
For sale is what you see in the top photo. You will have to provide your own hose and will need to modify the mounting bracket if you want to mount it like I did. The bracket in the bag is new and came from my new unit since I re-used my modified mounting hardware.
I'm selling it for $130 shipped (US only).
