The block for this engine goes all the way back to the Nova 4 cyl released in 61(cam in block). This newest re-design deleted the steel push rod cover. Copying the LS head surface design, access to the lifters is now through the widened head/deck mating surface; changed due to the wider LS head. The Chevy I4 and I6 were used in cars and trucks and by Mercury Marine I/O applications, I've seen them in farm equipment(Combines) Ag pumps and generators as well. Pontiac built the OHC I6 of 1964 by recasting the Chevy 250 as a Pontiac block. Same bottom end, water jacket, pistons and rods, When GM built the "Pontiac Iron Duke" 4(back to push rods for Pontiac) in the 80's(different design cross flow head?) designers changed the bellhousing mount to the 60*V6(corporate/narrower for FWD) pattern.
