This may sound crazy but I used a rope and ky jelly since I struggled with the tire wet. Did both sides in under 10 min from start to finish.
If it works...why not. I believe there are some hoses that have overall thicker walls that do not allow it to collapse as easy pulling through the tube. This may be why some guys pull by hand and others need a hand winch.This may sound crazy but I used a rope and ky jelly since I struggled with the tire wet. Did both sides in under 10 min from start to finish.
I tried by hand and couldn’t get pass 1/2 way with the tire wet. Took it out 2 times then said f it got a thing of ky. Lube the frame then the hose. I pulled it through with ez.If it works...why not. I believe there are some hoses that have overall thicker walls that do not allow it to collapse as easy pulling through the tube. This may be why some guys pull by hand and others need a hand winch.
1.35 OD. Couldn’t get last night so I walked away for the night.If it works...why not. I believe there are some hoses that have overall thicker walls that do not allow it to collapse as easy pulling through the tube. This may be why some guys pull by hand and others need a hand winch.
This is what I used, I have been using it for years to pull wire so why not. It completely evaporates also. Had both my hoses through in under 30min.1.35 OD. Couldn’t get last night so I walked away for the night.
+1This is what I used, I have been using it for years to pull wire so why not. It completely evaporates also. Had both my hoses through in under 30min.
Is one 32oz bottle enough to do the two hoses, and assume that you apply to the length of the hose?This is what I used, I have been using it for years to pull wire so why not. It completely evaporates also. Had both my hoses through in under 30min.
It is more than enough.... I only had about a quarter of a bottle and I did run a soaked paint roller through a couple times first.Is one 32oz bottle enough to do the two hoses, and assume that you apply to the length of the hose?
Thank you, This weekend I will put together a build post. Seems like I can find myself down a rabbit hole going through form after form lolNo one's laughing. We're all learning here.
We're to help each other out, not having to go through the same struggles we did.
A build log is a good idea though. Posting your progress and questions there.
