KingChuck24
So we got the wiring from DF yesterday and installed it in what we think is the correct way. We went to connect the battery terminals but whenever we go to connect the second one we get spark, not sure if that's an issue. I am very new to anything electrical and will probably need quite a bit of help with stuff like this. From other things I have read people test continuity, how do I do this? Do I grab a multimeter and where would I connect both of the leads. How would I check to see if the grounds are working? How do I check to see if some wires came loose? Also does the negative terminal that extends from the battery go to the ground that is attached to the battery holder on the frame?
Any help would be much appreciated, thanks!
