Northshoresaint's Standard City 09 SS/TC #238
Northshoresaint
I've been keeping a log of when I install parts on the chassis. Thought it might be interesting for a build log. Items in bold are donor or new parts. I completely disassembled the donor before purchasing the kit, but did not prep parts until I was ready to install on the chassis.
7/6/20 Purchased donor
9/2/20 Purchased LNF crate from ATK
9/18/20 Purchased Kit #238
12/2/20 Picked up kit from Red Oak
1/17/21 Began Assembly
4/16/21 First Start
4/17/21 First Drive
Build Progress:
1/17/21
R111 Chassis​
S112G Radiator Hoses​
P41B Lower (front) Bulkhead​
P41D Floor Pan​
S42I Clutch Line​
S42F Brake Line, Rear Master Cylinder​
1/18/2
P61B Floor Pan Strap​
K22B Brake Tees​
1/19/21
Steering Rack
K23B Steering Rack Hardware​
1/20/21
K22G Power Steering Bracket​
Intermediate Steering Shaft
1/22/21
Pedal Box w/ Brake Pedal
Gas Pedal and Sensor
Brake Pedal Sensor
Brake Booster and Master Cylinder
S21C Nylon Vacuum Line​
S42E Brake Line Left​
S42H Brake Line Right​
S42C Brake Line Front Master Cylinder​
1/23/21
Clutch Pedal and Sensor
2/2/21
Main Harness
Body Control Module
Gauge Panel
Ignition Switch
K22A BCM Mounting Hardware​
K21B Gauge Panel Hardware​
2/8/21
Battery Cables
2/11/21
L15F Heat Exchanger Mount Kit​
O22D Heat Exchanger Fan​
O22C Heat Exchanger​
S12A Formed Heater Hose​
S22B Heat Exchanger Tube with Brass Couplers​
2/12/21
O21A Radiator Del Sol​
K22H Radiator Mounting Hardware​
O21B Radiator Fan​
P11F Radiator Mount Structure (Bolt On Version)​
S12D Radiator Hose​
2/14/21
S42A Brake Line Front Left​
S42D Brake Line Front Right​
2/15/21
M14B Button Panel Set​
2/16/21
K15H Fuel Tank SS/TC​
Fuel Pump
I3V Fuel Tank Clamp Right​
I3W Fuel tank Clamp Left​
K22F Fuel Tank Hardware​
2/17/21
S82A Fuel Filler Hose​
Fuel Cap and Tube
Items assembled on crate engine:
2/21/21​
Alternator
Alternator Belt (New)
3/1/21​
Transmission
3/3/21​
Starter
3/4/21​
Engine Wire Harness
3/5/21
Engine and Accessories
K21E Transmission Mount Spacers​
3/7/21
Fuse Box Holder
Fuse Box (New)
K22E Fuse Box Hardware​
3/9/21
S12F Radiator Hose 72049 (Passenger Side)​
S12G Heater Hose 86050​
3/11/21
S12C Radiator Hose 70989​
S12B Radiator Hose 70846​
Hoses and Tees for Radiator
Positive Cable (Starter to Fuse Box)
Engine Ground Cable
Fuel Line
3/12/21
Coolant Tank
K22P Coolant Tank Mount Hardware​
P44G Coolant Tank Mount, Left​
3/13/21
Brake Reservoir
L22E Brake Reservoir Adapter​
L22D Master Cylinder Adapter Kit​
3/14/21
Subframe
Rear Control Arms
K23C Subframe Mounting Hardware​
3/23/21
O22G Intercooler Water Pump​
L22I Intercooler Pump Mount w/ Hardware​
P22N Rear Strut Mount (Top of Strut)​
L13C Rear Strut Mount Hardware​
3/25/21
Left Side Half Shaft
Jack Shaft (Intermediate Shaft)
Right Side Half Shaft
3/27/21
Battery
K24D Battery Retainer Hardware​
3/28/21
P42F Intercooler Mount Left​
P42G Intercooler Mount Right​
L21B Intercooler Mount Hardware​
O22E Intercooler Type 16​
O12D Intercooler Nylon Fittings​
L23E TurboCharger Outlet​
Rear Steering Knuckles
Rear Bearing Hubs
P12F Toe Link Rack​
L23L Toe Link Hardware​
O32H Toe Link Tie Rod​
O22M Rear Coilover Struts​
O22I Spring 300lb (Rear)​
N13A Rear Coilover Hardware​
3/30/21
N15C Rear Brake Rotor and Calipers​
?? Rear Stainless Steel Braided Brake Hose​
3/31/21
K15F Control Arms​
L23F Inner Rod End Hardware​
L23G Outer Rod End Hardware​
P42J Rod End Mounts​
4/1/21
O22B Front Shock​
L22G Front Shock Hardware​
O22J Spring 400lb (Front)​
P22E Front Suspension Upright​
L22H Front Upright Hardware​
P22I Steering Arm Left​
P22J Steering Arm Right​
4/2/21
Front Bearing Hubs
P32F Front Brake Rotor​
O32I Tie Rod End Goblin Front​
L22F Front Brake Mounting Hardware​
O32A Brake Caliper Front Left​
O32B Brake Caliper Front Right​
O31H Brake Pad Set Front​
M14B Front Brake Stainless Steel Braided Brake Hose​
4/3/21
Wheels, Tires and Lug Nuts
4/4/21
L23K Steering Column Hardware​
L32A Steering Column Fastener Kit​
O22N Steering Wheel​
Turn Signal/Headlight Switch
Boost Gauge
Driver's Seat (Temporary)
4/6/21
M11D LED Taillight Hardware​
M15J Taillights​
O23C Side Mirrors​
M12B Side Mirror Hardware​
?? Headlights​
4/7/21
S32A Silicone 2" 45 Bend​
S32B Silicone 2.5 to 2 Reducer​
S32C Silicone 2.75 135 Bend​
S32D Silicone 2.75 to 2.5 Reducer 90 Bend​
S32E Silicone 2.75 to 2.25 Reducer​
S32F Silicone 3 to 2.75 Reducer 45 Bend​
S52A Intercooler Tube for TC​
S52B Intercooler Tube After MAF for TC​
S52E MAF Tube for TC​
MAF
S52F MAP Tube for TC​
TMAP
O22A Air Filter 3"​
L23D Intake Hardware​
4/12/21
P11K Tunnel Cap, Manual Trans​
L21D Tunnel Cap Hardware​
Shifter
O42A Shifter Cable Manual Trans​
L23J Shifter Hardware for SS Kits​
L23O Rod End Style Shifter Hardware (Thanks ArkD!)​
4/15/21
N15D Solid Transmission Mounts​
N23C Solid Transmission Mount Hardware​
Brake Fluid
Transmission Fluid
4/16/21
Turbo Exhaust
O2 Sensor
P12D Exhaust System TC​
Engine Coolant
Northshoresaint
I discovered it’s best to have this cover in place before bleeding the clutch line. A 9mm wrench can easily drop into the transmission bell housing. By pure luck, I was able to locate it with an inspection camera and retrieve it with a small telescoping retrieval magnet.
Northshoresaint
On my OBD I’m reading 0 on O2 sensor 1 and.44 on O2 sensor 2. What should I be seeing? The .44 doesn’t change when I rev the engine.
Both should be jumping up and down. Technically the post cat o2 should be fairly steady, but without a cat, it’ll jump up and down.
CajunJeff
Looking forward to seeing this build! I live about an hour away, would love to check it out if you decide to bring it to a car cruise or something.
