Northshoresaint
I've been keeping a log of when I install parts on the chassis. Thought it might be interesting for a build log. Items in bold are donor or new parts. I completely disassembled the donor before purchasing the kit, but did not prep parts until I was ready to install on the chassis.
7/6/20 Purchased donor
9/2/20 Purchased LNF crate from ATK
9/18/20 Purchased Kit #238
12/2/20 Picked up kit from Red Oak
1/17/21 Began Assembly
4/16/21 First Start
4/17/21 First Drive
Build Progress:
1/17/21
Items assembled on crate engine:
4/16/21 First Start
4/17/21 First Drive
Build Progress:
1/17/21
R111 Chassis
S112G Radiator Hoses
P41B Lower (front) Bulkhead
P41D Floor Pan
S42I Clutch Line
S42F Brake Line, Rear Master Cylinder
1/18/2P61B Floor Pan Strap
K22B Brake Tees
1/19/21Steering Rack
K23B Steering Rack Hardware
1/20/21K22G Power Steering Bracket
Intermediate Steering Shaft
1/22/21Pedal Box w/ Brake Pedal
Gas Pedal and Sensor
Brake Pedal Sensor
Brake Booster and Master Cylinder
S21C Nylon Vacuum Line
S42E Brake Line Left
S42H Brake Line Right
S42C Brake Line Front Master Cylinder
1/23/21Clutch Pedal and Sensor
2/2/21Main Harness
Body Control Module
Gauge Panel
Ignition Switch
K22A BCM Mounting Hardware
K21B Gauge Panel Hardware
2/8/21Battery Cables
2/11/21L15F Heat Exchanger Mount Kit
O22D Heat Exchanger Fan
O22C Heat Exchanger
S12A Formed Heater Hose
S22B Heat Exchanger Tube with Brass Couplers
2/12/21O21A Radiator Del Sol
K22H Radiator Mounting Hardware
O21B Radiator Fan
P11F Radiator Mount Structure (Bolt On Version)
S12D Radiator Hose
2/14/21S42A Brake Line Front Left
S42D Brake Line Front Right
2/15/21M14B Button Panel Set
2/16/21K15H Fuel Tank SS/TC
Fuel Pump
I3V Fuel Tank Clamp Right
I3W Fuel tank Clamp Left
K22F Fuel Tank Hardware
2/17/21S82A Fuel Filler Hose
Fuel Cap and Tube
2/21/21
Alternator
Alternator Belt (New)
3/1/21
Transmission
3/3/21
Starter
3/4/21
Engine Wire Harness
3/5/21Engine and Accessories
K21E Transmission Mount Spacers
3/7/21Fuse Box Holder
Fuse Box (New)
K22E Fuse Box Hardware
3/9/21S12F Radiator Hose 72049 (Passenger Side)
S12G Heater Hose 86050
3/11/21S12C Radiator Hose 70989
S12B Radiator Hose 70846
Hoses and Tees for Radiator
Positive Cable (Starter to Fuse Box)
Engine Ground Cable
Fuel Line
3/12/21Coolant Tank
K22P Coolant Tank Mount Hardware
P44G Coolant Tank Mount, Left
3/13/21Brake Reservoir
L22E Brake Reservoir Adapter
L22D Master Cylinder Adapter Kit
3/14/21Subframe
Rear Control Arms
K23C Subframe Mounting Hardware
3/23/21O22G Intercooler Water Pump
L22I Intercooler Pump Mount w/ Hardware
P22N Rear Strut Mount (Top of Strut)
L13C Rear Strut Mount Hardware
3/25/21Left Side Half Shaft
Jack Shaft (Intermediate Shaft)
Right Side Half Shaft
3/27/21Battery
K24D Battery Retainer Hardware
3/28/21P42F Intercooler Mount Left
P42G Intercooler Mount Right
L21B Intercooler Mount Hardware
O22E Intercooler Type 16
O12D Intercooler Nylon Fittings
L23E TurboCharger Outlet
Rear Steering Knuckles
Rear Bearing Hubs
P12F Toe Link Rack
L23L Toe Link Hardware
O32H Toe Link Tie Rod
O22M Rear Coilover Struts
O22I Spring 300lb (Rear)
N13A Rear Coilover Hardware
3/30/21N15C Rear Brake Rotor and Calipers
?? Rear Stainless Steel Braided Brake Hose
3/31/21K15F Control Arms
L23F Inner Rod End Hardware
L23G Outer Rod End Hardware
P42J Rod End Mounts
4/1/21O22B Front Shock
L22G Front Shock Hardware
O22J Spring 400lb (Front)
P22E Front Suspension Upright
L22H Front Upright Hardware
P22I Steering Arm Left
P22J Steering Arm Right
4/2/21Front Bearing Hubs
P32F Front Brake Rotor
O32I Tie Rod End Goblin Front
L22F Front Brake Mounting Hardware
O32A Brake Caliper Front Left
O32B Brake Caliper Front Right
O31H Brake Pad Set Front
M14B Front Brake Stainless Steel Braided Brake Hose
4/3/21Wheels, Tires and Lug Nuts
4/4/21L23K Steering Column Hardware
L32A Steering Column Fastener Kit
O22N Steering Wheel
Turn Signal/Headlight Switch
Boost Gauge
Driver's Seat (Temporary)
4/6/21M11D LED Taillight Hardware
M15J Taillights
O23C Side Mirrors
M12B Side Mirror Hardware
?? Headlights
4/7/21S32A Silicone 2" 45 Bend
S32B Silicone 2.5 to 2 Reducer
S32C Silicone 2.75 135 Bend
S32D Silicone 2.75 to 2.5 Reducer 90 Bend
S32E Silicone 2.75 to 2.25 Reducer
S32F Silicone 3 to 2.75 Reducer 45 Bend
S52A Intercooler Tube for TC
S52B Intercooler Tube After MAF for TC
S52E MAF Tube for TC
MAF
S52F MAP Tube for TC
TMAP
O22A Air Filter 3"
L23D Intake Hardware
4/12/21P11K Tunnel Cap, Manual Trans
L21D Tunnel Cap Hardware
Shifter
O42A Shifter Cable Manual Trans
L23J Shifter Hardware for SS Kits
L23O Rod End Style Shifter Hardware (Thanks ArkD!)
4/15/21N15D Solid Transmission Mounts
N23C Solid Transmission Mount Hardware
Brake Fluid
Transmission Fluid
4/16/21Turbo Exhaust
O2 Sensor
P12D Exhaust System TC
Engine Coolant
