So it's been a while since I posted. The car has been going pretty well, just shaking down the whole thing. It's been a huge blast and keeps putting a smile on my face!
Today, however, didn't go to plan. My dad and I poked around the alignment and made some adjustments. We took it for a test drive, made an adjustment back home, and took it out again. I stopped to fill it up, and it clicked the starter relay before going totally dark when I tried starting it to leave the pump.
Normally I have to flip the headlights on before it will start. Kind of a weird quirk, but it worked. If I turn the headlights off after starting the engine, the gauges would typically stop working after maybe 10 or 15 minutes of driving, and turning the headlights on would fix it again. This time, I couldn't flip anything to make it work. I have a battery kill switch that cuts the ground to the battery, and I leave that off while the car is storage or when it's parked somewhere. Cycling that switch, the light switch, and the dash buttons, nothing got it to light up. I had to have my dad tow it home, which was very luckily a short distance (and very lucky they were in town and him with me)
My guess is the BCM is having issues since it's been centered around the gauges and dashboard, but I have no idea where to look. I don't want to just buy a new BCM because I'm not confident that would fix it, plus I'd have to get it scanned/programmed to the car by a Tech2 device owner. I just don't feel like it's the BCM failing because the Cobalt donor did not have issues like this at all - they manifested after building the Goblin. Does anyone have any tips on where to look? The battery was 12.5 volts when I got it home, so I feel like it's charging okay and holding a charge okay. My grandfather always said that the majority of electrical problems are in the connections, and that's just what my spider-senses are telling me.
