NRG vs 9Lives
finazzoty
Hi all,
At the point in my build now where initial aero elements are becoming a consideration and I'm curious...what are everyone's thoughts between the NRG CF wing and the 9Lives Big Wang?
This wing requires some fabrication to weld on the mounts and drill the adjustment holes - but yes it's significantly cheaper than comparable wings. The side plates can be ordered separately or can be made from 3/16 or thicker aluminum plate to the size you would like. Just put this out there for consideration to anyone wanting to save some $$ who can DIY the mounts and end plates.
Chubbs
what are your thoughts on the smaller side plates?
I'm also curious about this, if anyone has any info. I have read, I think on the nine lives website, the bigger end plates increases downforce. Neither the engineer or the pilot in me has any idea why.
If bigger end plates increased downforce (just lift, but in reverse) then why doesn't every airplane ever made have gigantic side plates on the end? Sure, some have little winglets, but those are for wingtip vortices, not for increasing lift.
I also have no idea why a gurney flap works. Vehicle aero seems to be more magic than science sometimes.
TravMac
Working on analysis as a day job (Structural, not fluid... but it applies), I can tell you that there's a lot of basic understanding out there, but the magic is in the details of numbers. I think seeing comments like "CFD tested" are funny because you can test a cow using software, and not really learn anything until you put it in context. Nine-lives has always been great for sharing those on the airfoil itself, and I think that is pretty cool to try and understand your car a bit better. Other wings don't necessarily give the data, and that's just not what some tinkerers want.
Now I'm sure the endplates have some details which also have small percentage increase in either efficiency or downforce, but it's probably not something you or I would notice over the wing in it's entirety. That being said... of course I ordered them because gotta have the pretty thing they sell. Most of the time, they just wiggle around back there because I think they lack enough stiffness... but again, they look cool. Gurney flaps are actually quantified in their effectiveness for the nine-lives analysis too, so that may help your understanding some more.
Metal Mech
Speaking of CFD testing for a cow, was sent this to let me know my anti-green Jeep Rubicon is the bane of the tree-huggers and climate change crowd...save gas, drive a cow.
I find this funny because back in my day (yep I said it) you didn’t buy a jeep for speed. You bought it for going slow off-road.
min fact I was lucky if I could get my to go 65 on the highway. Uphill it struggled to do 55 haha.
ah.b.normal
A friend that flew small aircraft said he often surveyed the cows in the fields on approach to reckon prevailing wind direction. Apparently cows try to face into the wind, prolly a herd instinct as it would carry any predator smells from upwind of their location. Funny, cows have cow sense and horses have horse sense, both peculiar and specific. I also drive a basically stock 17 COW(Jeep, Wrangler) 6speed! I've had it up to 85 on a highway, down hill, accidentally. It was not confidence inspiring. BUT she took on the Alpine Loop out of Silverton, CO last September. There were places where 2mph was too fast! Much 4 whl low! But she pulled us through with nary a hic-up, and many places did not look very promising! Engineer Pass at 12,000 ft. I was wishing I was on a motorcycle. For some jobs Aerodynamics ain't the be all and end all, but approach and departure angles rule.
jcdman
I got the wing logic aluminum wing for my car and install wasn't too terrible. I had to pay someone to weld the mounts on but I ended up fabricated some larger carbon fiber end plates.
Aero engineer here, so here's my opinion on endplates. Larger endplates themselves do not create downforce, however, they can reduce Drag and make a wing more efficient/stable
Drag is comprised of two types: parasitic (air interacting with the object) and induced (byproduct of lift). You can therefore reduce drag by making the surface smoother to reduce parasitic drag, or by reducing wing-tip vortices with an endplate. By reducing the vortices affect on the lower surface of the wing, it becomes more efficient, ergo "more" downforce and less induced drag. Here's a crude drawing to help visualize.
In short, differing pressure on either sides of a wing come crashing together at a wing's edge. Endplates mitigate the harsh collision and make wings more efficient.
OptimizePrime
Aero engineer here, so here's my opinion on endplates...
Respect, but long story short are they worth the extra $$? I get worth is subjective but are there material gains that even the layman can appreciate
jcdman
Our cars are so draggy as they are, you won't notice any difference from a small vs large endplate performance wise. The ones that came with the wing logic wing serve the purpose just fine.
LLBenJ
I'm running the NRG and agree that it's 90+% cosmetic. That part, it does well. For the guys getting serious with their cars a lot more can be accomplished.
