TheNuker
Does this axle angle look okay?
Nuker-
Nuker-
It is a little steep for stock axles, drive shaft shop axles could take the angle.
Brad
Take the weight off of them when you adjust them. Also screw the shock body out of the lower mount. Don't adjust the spring.So I guess I need to screw the coil overs up further? They are getting hard as heck haha
Nuker-
I had the same problem. You have to keep loosing them up then CRANK them down until you get them to seal. I felt like I was going to snap mine.Any solution for the rear brake lines that are still seeping? I have them as tight as I can go before the wrench on the hard line side wants to start rounding the nut.....
Nuker-
I put the T in the vent line that was supplied. Now when I corner hard left I get fuel running through it. Not sure how I’ll fix it but check to make sure that not your leakI seem to have a leak in my fuel tank, after filling I have noticed fuel leaking in the frame rail the tank sits on. Assuming I have a tiny hole in that bottom weld?
Nuker-
I wish that was it but I had a line of gas running on my garage floor to the drain from overnight. Doh!I put the T in the vent line that was supplied. Now when I corner hard left I get fuel running through it. Not sure how I’ll fix it but check to make sure that not your leak
Be careful with those vapors. Our neighbors house exploded and caught fire when a small gas can fell over and spilled gas on the floor. I'm sure your spill isn't as big, but take no chances.I wish that was it but I had a line of gas running on my garage floor to the drain from overnight. Doh!
I’ll give the rear brakes a try thank you!
Nuker-
