TheNuker
HP tuners log file.
Here is a 45min drive on (private) roads tonight with the ECU reset for a baseline.
Nuker
The first thing I notice is that the o2 sensor has no readings... So...
Isn't the IAT read in the MAF? I just replaced the maf with a brand new one..... You also see that the o2 sensor is not reading anything also right?Your intake air temp stays at -40F, and the fuel trims are a long ways from 0... nearly maxed.
Fix a few sensors, and it will be a lot happier. I'm amazed at how the ECU can compensate for missing info. My engine was running with a MAP sensor that was equal to outside air pressure instead of intake air pressure... somehow it was able to compensate for bad data!
So the new upstream O2 is plugged in.... Should I run the downstream instead? Getting really tired of new parts not working.Yes, the O2 isn't reading for me either. Usually the IAT is in the MAF, but I'm not sure on a LNF.
Can anyone confirm how many grounds there is on the LNF engine harness? I can't believe the MAF would read one but not the other. So **** frustrating.Check the wiring? Grounds? Might not be the sensors.
No IATs is a problem... that is info the ECU needs, and will affect fuel ratios. Maybe see if there is other parameter fields in HP Tuners that are being populated. Sometimes I grab the wrong param, and in reality, the data is actually populating. With your trim tables maxed, the ECU is not getting everything it needs.
Good point, I'll have to test again tonight I think I cleared them prior but i'll do it again just to be double triple sure. But one thing is for certain the IAT1 and O2 are not reading anything.How long since you cleared the codes? Some of that might be from when you had the coil issue if you haven't cleared them since.
I just wonder if you are still having the DTC's for the coils active. If so you might have some larger problem than O2 and IAT sensors.
