TheNuker
Hello everyone!
Donor is my garage and my little brother and I are starting to take it apart. Here are a few of the early shots from late last week. I'll upload some more current stripping shots later. No issues so far just working on figuring out how everyone comes apart.
I was really happy to see the passenger and both side curtain airbags are intact and in good shape!
List of current parts replaced with new / upgrades.
Fidanza Aluminum Flywheel part #198201
GM Performance Parts upgraded clutch kit GM part #19212712
ZZP LSJ Dual Pass Intercooler Plate Kit part #ZZ-DUALPIC
LSJ Throttle Body Gasket GM part #12575463
LSJ Supercharger Gasket GM part #12584342
LSJ Intake Manifold Gasket GM part #12597855
ZZP Axle Seals x 2 part #ZZ-3543
LSJ Exhaust Manifold Gasket [ZZP] part #ZZ-LSJEG
NGK Iridium IX Spark Plugs For LSJ x4 part #BKR6EIX-4
Exhaust Manifold Studs and Nuts part#ZZ-EMSNP (Nuts were rusted onto the studs" so replaced all)
Stock LSJ Belt GM part #DK060702
ZZP Ecotec Shorty Header Part # ZZ-ECTSHDR
ZZP Solid Control Arm Bushings part # K6698
ZZP LSJ 3 Bolt Collector Gasket part #ZZ-LSJ3BCOL
ZZP LSJ Axles-Stage 1 part #ZZ-LSJAXLE-S1
Moog front wheel hub bearing assembly part #513206
Moog rear wheel hub bearing assembly part #512250
Moog tie rod end part #ES800030
Moog lower control arm with ball joint driver side part #RK620898 (My donors ball joints were in bad shape)
Moog lower control arm with ball joint passenger side part #RK620897
Silicone Vacuum Hose Kit (Ebay kit no part number) (Many of the original hoses were in bad shape)
This is what I have so far, More will be updated as needed.
