As much as I love a good puzzle, this one is going straight to the scrap yard.Can't wait to see you put the cobalt shell back together.
I think GM tried that, it didn't turn out so well.Man why even bother with a goblin when you could have the coolest drop top G5 around!
I wish I had a boosted Cobalt!I don't recall seeing those other 2. The top black plug almost looks like the plug that goes to my boost gauge. but you don't have one of those.
The door ajar plugs look similar to Plug #3, but they are located on my body harness next to the door plugs.For plug #3 what does your door ajar plugs look like could it be one of them?
My donor didn't come with traction control but maybe the plug was just stuffed in behind the dash? I dunno.Mystery plug #2 could be traction control switch... I know it was the same connector as the trunk release and hazard lights.
I meant #1 (the one you sad was still unidentified. But I also missed where you said it was mirrored, so that's not TC - they were all the same.My donor didn't come with traction control but maybe the plug was just stuffed in behind the dash? I dunno.
Mystery plugs 1 & 3 are on the harness located near the Ignition Switch, Power Steering, and OBD 2 Port. I'm trying to think what else was in that general area? It seems like it should be the trunk release but the connector is a mirrored version, has 3 wires and doesn't plug into the trunk release button. I've identified Mystery plug #2 as the trunk release since it plugged right in.
