And there you have it! What Cobalt part would be needed for an outside the norm build? You guys don't use the seats, lights, wheels and other things already. Fuse and relay boxes can be made from Amazon/Ebay buys. The new engine/transmission will come with it's own wiring harness and computer to make it run. How much of the Cobalt wiring and computer stuff do you all delete now?
You can use most any brake booster, pedal assembly, hubs -(taking in considerations for if it will bolt to the DFKit front upright pattern). There are many other cars that use a 33 spline wheel bearing hub assembly. Some even with different wheel bolt patterns for after market wheels that you guys sometime re-drill or buy spacers to mount. With multi-brand parts it will still be a Goblin chassis. You will simply have to change your stories at the gas pump and shows as to what is used for the parts. You still will have trouble getting it registered in some states and through state inspections. Sounds normal to me but doable if you desire.
Yep! Guess I'm the bad boy outsider looking at the possibilities! The DFKit is a great little kit and growing in popularity. The global market awaits for a different drive train.
It's your car, whether starting with a DFkit chassis and kit options or build from scratch chassis, So make it yours - truly yours. Unique!!
YOU!! Y = at the cross road - which path do I take. O = going around in circles - trapped - where from here do I go. U = open ended thinking, the road isn't finished yet and if you put a small exit foot on the U then that is pointing to your next step forward.
You're on a life journey, enjoy it, take some family and friends along.
