The bcm is behind the passenger kick panel and has fuses in it in addition to the fuse box beside the motor.Is #19 in the large fuse box in back?
Hey guys, my fuses are good, but I'm not getting power power from the 2 wire connector going into the power steering module. Any suggestions on what to check nextThe bcm is behind the passenger kick panel and has fuses in it in addition to the fuse box beside the motor.
Thanks RossFollow the 2 power wires back to their source. From what I remember: The positive goes thru a 60A fuse, then battery 12V+. The ground goes to the frame. The frame goes to battery 12V-.
Use your electrical meter, and see where the issue is. Or are you asking how to use a meter?
