Towerdog
There are 2 wrenches for the BCR rear coil oversThere should have been one wrench for the rear and one for the front.
Yes. Replaced with Moog aftermarket ones.Did you have to press all the bushings out of the control arm before powder coat?
Which one did you order? What model QA1 shocks come with the Goblin? I alreadyDidn't receive a spanner wrench from DF for the QA1s, had to order one.
Thanks.Looking good!
Thanks. Figurativly and literally. I've always had concerns and anxitey about building and not fitting in it (short and fat). It got worse the further along I got and the fact that I went to a smaller seat made it worse. So relieved when I got into the car and there weren't any issues. Not the comedy act of getting in and out is a different story...Look’n good.
feels weird, doesn’t it?
It looks like its one of these;where did you get your mirror?
Same here I guess I didnt look at it from the back, Im thinking more like a 8-10" wide.It looks like its one of these;
15" Wide Rear View Race Mirror Ultra Clear w/. 1.75" Clamp for Honda RZR UTV | eBay
If so, I bought a similar one that is 14" and decided it's way to big since at my height I'm almost at eye level with it and it will block to much forward view.
Something like this might work but at 8"x4" it seems way to tall.Same here I guess I didnt look at it from the back, Im thinking more like a 8-10" wide.
I think you meant to type:I can send you some extensions. But for now, you can maximize the length of everything and get it diving.
The first adjustments will need to be made with the shifter off of the tunnel.
Instructions here.
Until you get the extensions you will need to install the rod ends onto the shifter cables only about three turns. And the big adjustment nuts on the shifter cables will need to be bottomed out. This makes the cables think they are longer. This should get the bell cranks close enough to vertical that it will shift.Manual shifter installation and adjustment
Step one Install your tunnel cover. Step two Install your shifter cable bracket Step three Identify one of the cables on both ends with a sharpie mark or piece of tape. Route your two shifter cables along the tunnel and through the opening in the firewall. The cables need to be positioned...dfkitcar.com
Send a message to support@dfkitcar tomorrow and we will get a set of extensions sent your way.
