If your frame is painted or powder coated, it has a hard time grounding through the frame. Using a grounding cable ensures that it does have a good ground.I put a charger on the battery and it showed 95%. I let it charge to full. I didn't notice the lights going dim; I will check that. As to engine/transmission ground I would have thought it grounded to the frame. I have not installed a ground cable and would not know where to attach one, either end. I'm curious as to why the engine has turned over a few times, although it didn't start.
I believe originally the large black ground cable was bolted to one of the transmission bell housing bolts between the engine and transmission. Otherwise any large bolt on the engine block that is clean and not painted will do.I am sure I can find a ground lug on the frame, but where is a good place on the engine/transmission for a ground cable?
I think that’s where mine was and I hooked it up the to sub frame I believe.I believe originally the large black ground cable was bolted to one of the transmission bell housing bolts between the engine and transmission. Otherwise any large bolt on the engine block that is clean and not painted will do.
I think the refresh rate on the ECM/BCM is 15 minutes(?) and clears out some codes that are no longer valid on its own.I found our scanner and went to clear the codes and they had already gone away before I even plugged in the scanner.
The above should read 'that could be operator error.'I got the trans fluid leak located and fixed, so I tried starting. Engine still cranks, but doesn't start. I did notice the butterfly 'fluttered' a little, and I tried to see if the plugs were firing and they weren't, but that could be opI'm still at a loss in tracing a data wire from BCM to ECM. It still feels like two steps forward and a step and a half back, but I do feel progress, however painfully slow.
