In one of the pictures above, you're focused on the big rectangular red BCM plug ... the data pair does not go to this plug. I believe it goes to the vertically-oriented blue and gray plug, though I might be misremembering and they go to the horizontally-oriented one instead. Please disconnect and reconnect both of these plugs, taking good care to apply lots of pressure on both while you close the latch. While you have these plugs out, you should observe the BCM for bent pins, and should use compressed air or a small brush to clean up the blue/gray connectors.
But, that is neither here nor there; with the ignition in the ON position (lights on in your cluster, primed fuel pump), do you see any of the following?
- Coolant temp -40 in the cluster
- "POWER STEERING" message in the cluster
- Inaccurate fuel reading on the gas gauge (empty)
