Need some help with a rear diffuser design (I have zero aero knowledge).
I made the bottom of my subframe flush with the bottom of the chassis, so enclosing the bottom of that will be pretty straight forward.
I'm thinking riv nuts in the stock rear floor pans to bolt up the leading edge, and then drilling the subframe and using these automotive push clips to retain the rest of it.
Would these be sufficient, or are the forces high enough that everything should be riv nutted and bolted?
I drew up a thing that kind of looks like a Lotus Elise diffuser.
I'm thinking match the DF floor pan material thickness for the main piece and using 1/8" aluminum for the side pieces. These 3 pieces would be riveted together.
I went a little thicker on the side pieces because they're kind of hanging out in the middle of nowhere. Thinking maybe some little struts or cables might be needed to strengthen further?
Any comments/suggestions for improvements would be greatly appreciated.
