Rear Toe Link Rack
KingChuck24
Any good pictures of this, I searched the forums for a little and couldn't find any? Also any good ones of the rear sway bar, I am 90% sure I got mine in correctly just want to be 100%.
Here is one picture I found,
36497
This one has a bar running across it, would that be one of the steel parts DF provided?
Yes, it's a steel bar that the DF supplied tie rods and the front tie rod ends mount to. My photos aren't great, but hopefully it helps add context to the one you found already.
Edit: my photos have the bar upside down. Do it the way below in posts #7. I swapped mine to the correct position and it made a huge difference with higher speed bumps. My rear end doesn't pucker as much when hitting bridges or asphalt changes at highway speed now.
2022-08-28 Rear Stabilizer Orientation.JPG2022-08-28 Rear Stabilizer Setup.JPG
jamesm
That toe link bar is upside down. It will have a ton of bump-steer if you leave it this way.
Just curious, what will cause the bump steer if it's upside down? Isn't the unit and hubs still fixed in place regardless of what orientation it is? I'm asking for knowledge and learning.
RCK605
Bump steer is caused by suspension geometry and the tie rods. The tie rod end is a fixed length and travels on an arc as the wheel moves up and down over bumps. This essentially moves the tie rod end in or out, which then pivots the wheel and changing your alignment.
jamesm
I'm sure one of the engineers can give a more detailed answer, but the TLDR is when it's upside down, it increases the angle of the tie rod. This causes the wheel to toe in/out as the wheel moves up and down
The toe link rod needs to be as centered as possible iwhen the car is at its neutral normal ride height position. That minimizes bumpsteer as it travels above and below the neutral point.
Nah, this was a good enough description.
Josh's09
I need this one (red arrow):
38350
Although, thank you for including the top image, I will need that eventually.
Scott #321
A helpful link
I'm also trying to figure out how to get the toe link mounted. I'm having issues finding the bolts. Do you know what size bolt, length, and thread pitch the bolt should have? I may have to buy new ones but I don't know what to buy.
Thanks in advance for the help!
