andyseavers
Can anyone explain how to get this control arm off the knuckle? I didn’t see it in video 3.
Get a ball joint removal tool.Can anyone explain how to get this control arm off the knuckle? I didn’t see it in video 3.
I’ve used the Harbor Freight version with good success.Get a ball joint removal tool.
The Pickle fork works if you don't mind destroying the ball joint. A ball joint separator will not harm the part.
I believe the tie rod end mounting point is different as well but I don't think that makes a difference for the RWD application.Dimensionally everything is the same on the TC knuckles except for the ball joint stud. It's 1 mm bigger in diameter. Not sure which car you have but any knuckle should work unless you have a TC then you'll need to get TC knuckles.
