They should still both work since they are both just momentary switches that ground the signal.After looking at the button diagram chart for installing it, I think you are right.
I may have them mixed up on what I connected on the button panel then....
I wonder if you were following the button panel wiring for the late model LNF cars.@Ross Thank you for the diagram, I'm not sure what it is telling me though. Where on the BCM or Fuse Box does it end up leading to? I don't understand where the green wire is going after it leaves the button on the panel. Was I supposed to have a ground? Because for the button kit, I just soldered two lines with connectors off the green/white wire. I remember it being bright green, not dark green.
For the diagram, is it saying that the wire to the button kit should go to pin #2 on the gauge panel connector?
First thing I'm going to check is the button itself on the button kit. I should get continuity when I press the button, correct?
Thanks, you'll get there. I don't think there was a point in the build were I thought I wasn't going to be able to do the work. Just small tasks and it'll be done before you know it. There were a lot of things I didn't understand, but knew the guys/gals here had most likely seen it before. I'm calling my build done but we all know that story. I want to change this or that but I'm just doing the small things right now. Once I get a better feel of what this thing is, then I'll know what more I want to do.Just looked at some of your car pictures. That looks awesome! Hard to envision right now, but congrats!
I love the "actual" picture in a previous post of your son on one of your drives (Tim Curry)
I could do that then just pass it on once I'm ready to do the full shebang. I do have an OTTP solid shifter linkage and found Mayor West's file to make a spacer to fit on the DF rods. I plan to install that on the front/back part. That plastic unit is a poor design. So poor, in fact, that I am carrying a spare set in my Goblin just for when the next one breaks. I assume they fail in Cobalt trim since both OTTP and ZZP sell versions of those links.You could always pick up a group buy shifter if you see one pop up for sale. It uses the original tunnel cap and, while people have said that the DF-designed shifter is better, the group buy shifter is a massive, massive upgrade over stock. Those flimsy plastic clamps are just an atrocity.
Source: me, I have had a group buy shifter since SACTX sold a run of them a while back.
I'm getting 14 to 16 mpg on E85 depending on how I'm driving.Also, been driving a good bit. This thing loves to drink the fuel. Just curious, once I get over the thrill of acceleration (if you ever do) what type of gas mileage does everyone see? Just cruising and driving more spirited if you happen to know it.
