I suspected a lot of things, springs, shocks, alignment, wheel bearings, tie rod ends, steering rack, etc.
The new video evidence shows caster change. The A arms should prevent caster change.
The brakes are able to apply a twisting force to the billet uprights, and the A arms are suppose to transfer that force to the frame, and prevent caster changes.
Caster is allowed to change (Edit: On some cars true, but not on our Goblin)
as the suspension moves up & down, but not when the billet uprights want to twist.
After the tires start bouncing, then the springs and shocks have to deal with that secondary issue... but the first issue is too much A arm movement. So springs and shocks have little to do with the caster changing.
I have had always wheel hop under hard braking. For 2 years I have been trying things to fix it.
I've tried 125 lb/in springs, 300, 400 and now the 225/475 springs.
I've tried 215mm Toyo Proxes (from my Cobalt), 315mm Nitto NT05, and now 275mm Toyo Proxes R1R.
I replaced the wheel bearings from the Cobalt ones to Moog.
I changed to steering tie rod ends to the correct ones after Lonny pointed out I had the front ones on the back of my car. This allowed me to bring the front wheels in closer to the frame, which helped make the A arms a bit more rigid.
I've checked the shocks, they work, and tried 0,2,4,6,8,10,12,14,16, and 18(max) clicks.
I've checked the steering rack. It seems fine.
I've tried different wheel alignment numbers,
1.5 degrees camber, now 0.7
8 degrees caster, 5 degrees, now 6.
