Thanks to
@1966tbird for getting me his 18mm anti sway bar. I decided it will go on before my next autocross in 2 weeks.
I bought the too-long antisway bar links, before I knew I was suppose to get the shorter ones. So I went to the hardware store, bought a 3/8" turnbuckle,
View attachment 32260cut the loops off the end, and welded on the ends of my too-long sway bar links.
View attachment 32252 View attachment 32253
Now I have one adjustable sway bar link. Don't have the scales to cross balance my car, but one step at a time.
That green circle is a GM custom bolt... with a 10mm hex head inside the frame, and a external torx E10 on the outside. Luckily my 2nd donor still had these in the sub frame. Still need to set the camber on the rear wheels, as I had to swap the rear struts, as I had the swaybar mounts facing forward. Doh! I see I had my shocks set at 25 clicks up from bottom, only 32 clicks in the full range.
