Ahh! Fabrication!!!
Is that essentially what OTTP's front balance shaft delete bushings do? You're running an EWP, right? Are you deleting the water pump chain? Do you have a provision to block the oil feed to the short chain tensioner? Or... do I misunderstand the situation? Which is completely possible!I drilled and tapped a M4 hole thru the aluminum bushing, into the steel 20mm plug I made.
The little M4 bolt will keep the plug from moving. Needs some red loctite, as I wouldn't want to loose my oil pressure.
Yes.Is that essentially what OTTP's front balance shaft delete bushings do?
Yes, and yes I am deleting the chain. There is a pretty long discussion around removing the thermostat, and placing the EWP.You're running an EWP, right? Are you deleting the water pump chain?
It is on my list, but I haven't started that yet. You got the picture... including my future mods!Do you have a provision to block the oil feed to the short chain tensioner? Or... do I misunderstand the situation? Which is completely possible!
I've been following!Yes.
I thought I was doing a good job of being patient in waiting to ask my questions until your most recent photo update, I wanted to ask them after the previous update but I waited as long as I could!It is on my list, but I haven't started that yet. You got the picture... including my future mods!
My take was, because it says they're meant for removing the factory water pump chain or running [a] short chain, they don't use the chain sprockets. If their grooved plug goes in the exhaust side, it'll still supply oil to the factory water pump chain tensioner for use with a short chain, or the solid plug in the exhaust side cuts oil flow to the tensioner. I think it gets confusing when folks call the factory water pump/balance chain the "short chain" when it's really the shorter chain, and the actual short chain is a water pump-only chain that doesn't run to balance chain sprockets.Yes.
Kind of... Those OTTP parts look like the cut off end of the balance shafts, so they would still need the sprocket and bolt to be installed. My method held that part in place with a M4 bolt, and some red loctite. Guess you could install it either way, if you have a drill and a tap.
Are those OTTP parts bigger than 20mm?
They might be the size of part #4 here. I'm not sure...
Quick question, if I just remove the water pump chain. Leave the balance shafts and water pump installed. Do I have to worry about the oil pressure due to the balance shafts not spinning or the chain tensioner having no chain to press against?The old chain tensioner for the water pump & balance shafts is floating up in the orange square.
The orange arrow points to its normal location, where I tapped a M6x1.00 into the oil hole for that tensioner. Effectively blocking the hole with a M6 bolt.
The OTTP Balance Shaft Delete Front Plugs must be 42mm big, in order to block oil feed to the balance shaft chain tensioner.
The exhaust side balance shaft (orange E) has 2 oil holes (green lines), while the intake side (orange I) only has 1.
if you’re not running the balance shaft chain you’ll need to make a block off plate for the tensioner cause it’ll be a leak if left off. I have seen a balance shaft tensioner come apart but I wouldn’t trust it without the chain or tensioner shoe to push on.Quick question, if I just remove the water pump chain. Leave the balance shafts and water pump installed. Do I have to worry about the oil pressure due to the balance shafts not spinning or the chain tensioner having no chain to press against?
