Replaced the spark plugs, checked compression. I've owned the LSJ for 1.5 years, guess it is about time
The old plugs were AC Delco 41-106 Iridium, the new ones are NGK BKR7E 4644 standard plugs.
Gapped to 35 thou, and torqued to 20 ft pounds.
Any opinions on reading these old plugs?
Compression on a 200K mile LSJ:
Cylinder # | 3rd hit | 6th hit of compression in PSI |
1 | 150 | 175 |
2 | 145 | 170 |
3 | 150 | 175 |
4 | 150 | 170 |
I tested Cyl#1 before I pulled all the spark plugs, and the numbers were lower, as the starter had a harder time turning over the engine.
Went back after all the plugs were out, and retested it, for consistency. It was 145 / 160 with the other plugs in.
