Work has been hectic, so just doing odds and ends when I get home. I noticed when purging the cooling system That the IC coolant never really moved. I brought home my Tech2 and commanded on the ic water pump. Just as I suspected, the ic pump is not working. I check power and ground, then the old school “tap test”. Yep. It’s toast. Woohoo
I also checked my fan wiring and for some reason, there’s no power. Long story short, I went to the secondary fan wiring and it’s good to go. I’ll probably add an override switch so I can turn it on whenever I want, which with Texas heat, will be a constant on from startup.
hopefully this weekend I/we can complete the front suspension and brakes, so I can start bleeding everything.
