SACTX
Updated 12/13/20
9/13/21
I’m updating the first post in my log with the actual build specs and and any custom things that I did. If there is something on this list that you’d like more info on, please post or message me.
Thanks!!
Standard length track frame
Donor 2007 SS/SC 130k miles
Kit purchased 4/7/2020
Donor purchased 4/13/2020
Kit pickup 7/24/2020
First start 9/25/2020
First drive 10/12/2020
Registered 11/19/2020
Frame color: Prismatic colors Striker Gold Deluxe over Sparkle Silver
Body panel color: Hyundai 930233 Titanium Gray
Motor:
LSJ with stock internals
Tvs1320 with 2.9 pulley
OTTP BRFPS
60lb injectors
Dual pass endplate
ZZP phenolic spacer
OTTP oil cooler relocation plate
Dual Evil Energy (Amazon) 3”x12” oil coolers
Aftermarket coolant tank with “ghetto” shielded 15 psi pressure release
Intercooler filler neck/reservoir (Goodwin Racing https://www.good-win-racing.com/Mazda-Performance-Part/61-2618.html)
Remote rollover vent with negative pressure valve to seal tank
ZZP shorty header
DF exhaust
Switched coolant and intercooler fan control
To come:
Custom 3” exhaust
Stage 2 cams
ATi overdrive harmonic balancer
Transmission:
New F35 with LSD
4.45 final drive
SouthBend stage 1 clutch
ZZP lightweight flywheel
Aluminum Shifter
Body:
RunCool hood louvers
Sealed footwell cover
NASA ducts with finished cutouts
6mm Alumalite full front floor with splitter and reverse scoop for intercooler
6mm Alumalite side splitters
PCI Racing 60” rear wing on DF supplied mounts
Full front windshield from 1/4” impact and scratch resistant plexiglass
Fabric roof (from Jason)
Front grill screen
Engine cover
Custom Side Scoops
Rear diffuser
Side Splitter skirts
To come:
More rear cooling
Interior:
Corbeau A4 seats
Corbeau sliding mounts
DF button panel
NRG 3-spoke suede steering wheel
NRG quick release with 3-6 bolt adapter
Footwell led lighting
Dual Aeroforce Guages
Front/rear motorcycle cameras (MotoWolf M6 Plus)
Boss audio 3 1/2” round headunit
Boss audio 4” 3-way front speakers
Power Acoustik 1 1/2” front tweeters
Rockville 10” powered sub
Noico 150 mil sound insulation on back firewall and footwells
BlackDiamond grip tape in footwell
Shimmed steering wheel (aligned with driver's seat) - https://dfkitcar.com/forum/index.php?threads/adjusting-steering-wheel-alignment.1996/
Running gear:
18x11 Motegi Hypergram wheels
335/30 Toyo R888r tires
1 1/2” adapters 5x110-5x114.3
Brake balancer
Parking brake kit
EBC Yellow Stuff pads
225-475 progressive 10" front springs with DS403 shocks- 225-475 progressive 10” rear springs
Solid rear control arm bushings
Alignment specs to follow
Rear sway bar
To come:
A secret project for the rear control arms......
9/13/21
Thanks!!
Motor:
OTTP BRFPS
60lb injectors
Dual pass endplate
ZZP phenolic spacer
ZZP shorty header
DF exhaust
To come:
Custom 3” exhaust
Stage 2 cams
Transmission:
New F35 with LSD
4.45 final drive
Aluminum Shifter
Body:
Front grill screen
Engine cover
Custom Side Scoops
Rear diffuser
To come:
More rear cooling
Interior:
Corbeau A4 seats
DF button panel
Running gear:
Brake balancer
Parking brake kit
Rear sway bar
To come:
