2006 LSJ Donor. Trying to attempt a first start or at least get the fuel pump primed. I hear a click from the BCM when turning the key to the on/ready/prime position. Console displays a security light. At first attempt, I didn't even have the light come on and rechecked all my grounds. Starter has the extended wire + purple wire setup correctly. I can get 12v to the fuse block. I have a few connectors not connected in the rear, the radiator fan, a purple plug and the coolant overflow tank sensor. All grounds up front go to the steering box ground since the tunnel ground did not have a good connection, thinking of just running the extended tunnel ground directly to the battery ground post. Two grounds in the rear, which I believe is fuse block + harness. Looking for some advice on troubleshooting further.
