DanPerryy
So in both cases, the axle popped out with the suspension bottomed out. From the picture the axle looks level without a load, so as the suspension collapses the axle needs to grow. I wonder if you can reduce the rear track width by remaking a new adapter that moves the rear hub inward the 1/2 inch on each side. I think you will either need a bit longer axle or reduce the track width. The track width can then be re-extended with wheel spacers.
