SkyRay
Thanks for all the responses. I guess one of the benefits of doing the wire harness yourself is having the extra connectors afterwards. Since I didn't do mine, I didn't have the extra connectors. I did find a pigtail on Amazon for under $20, so I went that route. I might have been able to solder it, or use a solder sleeve, but it was really short (1/8") so I didn't want to chance it. I really want to get the car completed and be able to use it vs trying to make it work and then potentially troubleshoot issues down the road.
Now for some thoughts on the installation of the solid transmission mounts.
- I wish I had installed the solid transmission mounts before I completely torqued down the subframe connections.
- I placed a floor jack under the transmission, right under the front mount.
- I loosened all 4 subframe connections and the 4 bolts holding the control arms to the subframe
- I loosened the 6 bolts holding the engine to the chassis. These steps maximized the tolerance (slop) between the transmission and the subframe.
- I installed the rear transmission mount, starting (but not torqueing) the three bolts going from it to the transmission.
- I installed the front transmission mount, starting (but not torqueing) the lower bolt going from it to the transmission.
- I used a rubber mallet to force the front transmission mount between the plates in the subframe. Maybe you have enough of a gap that yours went in easily... mine did not. I got the hole in the mount as close to lined up with the holes in the subframe as I possibly could.
At this point, all of the mount holes to the subframe were forward of where the subframe needed them to be.
- I got my quick clamp, and reversed it so that it was pushing the ends away rather than clamping them.
- I installed it between the subframe and the transmission/engine, at the front of the subframe.
- I used the clamp to push the engine away from the front of the subframe. I was pretty quickly able to drop the three screws through the rear transmission mount and subframe.
- I had to do more work to get the front transmission mount hole lined up with the subframe holes. There wasn't much around there for me to lever against, so I did end up using the rubber mallet again. Once lined up I installed (but again didn't torque) the bolt down.
- This left the top bolt on the front transmission mount that needed to be installed. This took a combination of lifting the engine with the floor jack (remember it was right under the mount) and prying between the mount and transmission right beside the hole. Eventually the hole lined up and I was able to start the screw.
With all the screws started, I then went to torque down the screws... I went in this order:
- Transmission mount to transmission (5 bolts)
- Transmission to subframe (4 bolts)
- Engine to chassis (6 bolts)
- Front Subframe to chassis (2 bolts)
- Rear subframe to chassis (2 bolts) through the control arms
- control arms to subframe
Not sure if this is the best way, but it worked for me. Sorry I didn't take pics of every step... hopefully you can follow what I did.
