Sluggonaut
See post #365 above from Gtstorey for the link.Where can a new unit be had? I’d be very interested in one.
I put the part numbers for the fusebox and bracket a few posts below that also.
2006 SS/SC shows a different part number and a $317 priceSee post #365 above from Gtstorey for the link.
Thanks! Exactly what I've been searching for unsuccessfully.That coat hanger holds the caps on the master brake, part of the brake reservoir relocation kit.
There is extra stuff in this picture that isn't stock DF.
A brake reservoir picture is here.
are there any aftermarket wiring harnesses out there that will meet the Goblin requirements to make things much simpler and a more cosmetic appearing?I've been watching the wiring harness instructional videos list in the Build Video section, but I keep seeing references to the "new" wiring videos in several threads.
Which ones should I be watching exactly? The ones in the Build Video section or DoyleFab on YouTube or other?
Thanks in advance!
I guess you are asking about the short leg of the L that sticks up vertically?@Sluggonaut
The front of your tunnel cover looks significantly different than mine (#187). Did you make modifications or did your tunnel come like that? (Just wondering)
That's one of the 3-piece tunnel cap that comes with the DF shifter.@Sluggonaut
I definitely don't need longer, my problem was too much of the harness on the BCM side of the trunk. It was a fairly easy fix once I was able to get everything unwrapped.Maybe consider concentric wiring method? I know it takes a long time for wiring and this will make it longer.
Dale
CorrectI guess you are asking about the short leg of the L that sticks up vertically?
Understood. I'd probably insulate the metal where the wires are, unless the edge of the metal is duller than it looks. That'd be a wear point, down the road.That's one of the 3-piece tunnel cap that comes with the DF shifter.
I am not sure what the regular tunnel cap looks like. I ordered the DF shifter and it was shipped with my kit - I didn't receive the regular tunnel cap.
I was going to pick up a brake hone and work the shock eye per QA1's recommendation.If you want to ship them back to us I will compare the dimensions to ones we have here. If they are out of tolerance I will swap them out with a set we have here.
