While on the topic of the front end, I have a front tie rod question.
Using the notes I collected from reading other build logs and researching the topic specifically, I installed the tie rods/ends that came with the kit on the front and will be using the replacement Cobalt parts on the rear toe link.
This research also revealed that a good starting point for the outer tie rod ends is about 1" of threads showing including those under the jam nut. However, when I do this both my hubs are facing significantly outward and to get anywhere near straight on both sides I have 2" of threads showing, leaving about an inch of thread inside the rod end. I likely need to move them out some more, but I won't know for sure how much until the initial alignment some time down the road.
I know the number of turns lock-to-lock differs between the SS racks and the regular racks, but is there a difference in which tie rods I should be using on my SS rack? If the ones in the kit are shorter, it seems like the longer ones may be a better option so I have more threads covered by the tie rod ends.
