Sluggonaut
I can't find any diagrams of the multiplugs in the images and PDFs I've found/saved so far.
I am curious as to what this red w/white strip wire is before cutting it out. It is 2 spots over from the CHMSL/3rd Brake Light wire on the small gray multi-plug:
I also traced the 3 sunroof wires, with the 2 small ones going to the red BCM multi-plug and the thick purple wire running to the large white multi-plug. I am curious if the larger purple wire is power for the sunroof, as I've read conflicting information as to whether that is a RAP circuit or not. If the sunroof circuit is RAP, I would consider keeping whichever is the power wire for a RAP accessory connection:
Appreciate it if anyone can locate wiring diagrams for either plug so I know what I am cutting in the first instance and whether to keep or remove in the second instance. Thanks in advance!
