I can really use some help with figuring out which connector is which in the Alldata wiring diagrams. I've found the various BCM C1 - C4 connectors and have identified some of them, but not sure how to tell where the dash-to-body connector and its pinouts can be found.
@Lonny
I am at the first step in the Combining Harness video where I need to extend the twisted data wires. Way back at the beginning, I added the extensions to the data wires by the ECM and ran those down to the BCM.
A few posts ago, I mentioned the problem I ran into of not having either the RPD or Boost Gauge connector as expected in my 2007 SS/SC, but I did have the twisted brown wires coming out of my body-to-dash connector (pins C5 & C6).
The brown twisted pair wires were cut at the connector to get rid of the connector and they run into the already taped bundle at the BCM. I'm not sure where they go, but I can cut open all the wrapped bundles if I need to. I don't have any other twisted brown wire pairs left, so I am assuming these are what gets connected to the extensions from the ECM. I just want to make sure this is correct as it doesn't make a lot of sense to me, nor does it resemble either option in the video - running to the RPD/boost gauge down by the ignition or connecting back on the main harness.
Mine has twisted brown wires coming out of the BCM headed towards the ignition on the dash harness with the ECM extensions coming around the main-to-dash harness corner and meeting there. If there was an RPD/boost gauge at the end of the data wires I understand where they are going but if they are just running to the BCM, is it terminated in there somewhere?
Any insight from anyone would be appreciated.
Thanks in advance!
edit: I just tore everything back apart on the BCM side and the dash-to-body C5/C6 wires go to this spot on the BCM connector:
If this is BCM C2 pins 2 and 20, then these are the High Speed GMLAN Serial wires (+ and - respectively) and should be connected to my extension coming from the ECM. That's as close to a solution as I can come up with, but not sure.
