Yea... looks like a tune or a tuner will be in order this winter... for first I thing 250 rpm would be good and 150 for second would make a world of difference. You ears can only do so much and trying to watch the tach on a launch is less than ideal.Sure can. Pick any RPM you want to limit.
Maybe the Fuel Cutoff RPM by Gear works for the automatic, but my standard never shifts thru the gears in this table. I think it all 1st gear according to the PCM. But that becomes the RPM limit for the engine.
Ya gotta just start shifting as soon as you push the gas to the floor Got about 1/2 second in first gear to redline LOLHas anyone installed a shift light. I hit the rev limiter way to often in first.
If you have the standard transmission, you don't get to pick RPM by Gear. That only works for the automatic transmission.Yea... looks like a tune or a tuner will be in order this winter... for first I thing 250 rpm would be good and 150 for second would make a world of difference. You ears can only do so much and trying to watch the tach on a launch is less than ideal.
I think the ECM stops at 8192Sure can. Pick any RPM you want to limit.
Yep. Exactly. It wraps out quick in first.Ya gotta just start shifting as soon as you push the gas to the floor Got about 1/2 second in first gear to redline LOL
Nuker-
P/N of the springs?Stiffer springs in rear. Also I put the 1 inch longer qa1s on the front and the tires are a little more capable of contacting the ground in the front when weight is transfered to the rear now. I am running variable rate like Ross on the front.
I'm using using the Qa1's in the rear because I modified an upper a-arm into the rear. But the qa1's and BC's are the same 2.5 id I'm using this in the front with the 1 inch longer qa1'sP/N of the springs?
Yep. I did the same and lIke them much better, so far.Also I put the 1 inch longer qa1s on the front and the tires are a little more capable of contacting the ground in the front when weight is transfered to the rear now. I am running variable rate like Ross on the front.
Which shop did you use? Are you satisfied with their work and price? I'm starting to explore that since my frame is coming up soonish in the queue.She’s went off to the powder coater this morning
Was this something that you just mentioned to DFK as "I want harness bar" and they knew what you wanted, or did you have to send them drawings and dimensions and specifics that you came up with yourself?Nope. I had DF weld in a harness bar higher up. I want to get it built ASAP to get it registered and enjoy it for the summer. Then next winter start changing the things I don’t like. If I like everything then MORE POWER BABY!
I used supreme powder coating on Grosebeck . There are two of them you want this one. Did a good job and got it done quickly. I did have to take the tunnel cap back because it was a bit lite but he fixed it that day.Which shop did you use? Are you satisfied with their work and price? I'm starting to explore that since my frame is coming up soonish in the queue.
You could try it this way as well:Does anyone have pictures of theirs footwell cover installed. I’ve been fighting with mine to get it all the way back to upright bars. I even took the power steering motor per Lonny’s suggestion to see if it would help. Any close up pictures from the front and side would be much appreciated.
So you have reworked 2 harnesses now, I'll be dropping mine off friday! lolNot a bad days worth of work. Completely replaced the engine harness with a brand new one from GM. Also replaced the valve cover gasket while I was at it. Looked pretty clean inside. Not sure if you can see it but there is at least 15 wires in there missing insulation. Also found the MAF wire had been spliced 6 times plus several other sensor connectors replaced. Though it would be best just to replace it all with new.
