I soaked my entire harness (in sections) in paint thinner to remove the stickiness. Worked very well other than it causes the connector seals to swell, so they should be removed first. Then I rinsed it with water to remove the paint thinner and then a quick bath in alcohol to remove the water. Worked like a charm.The best part is you get to deal with the stickiness left from the tape the WHOOOOLLLEEEE time you work the harness >.< I went through half a box of gloves doing the harness. I found Clorox wipes cleans up the stickiness from your hands pretty nicely (from when dexterity is needed and gloves come off)
