Oh, I did that as well. In fact the size/method of rolling was the exact same. As long as I was grabbing the same gauge for an extension (for example all of the dash wire extensions) I tried to match colors as close as possible.Please tell me I’m not the only one to do this View attachment 21074View attachment 21074
glad to see I’m not the only one who got heartburn from the wire harness work hahaWell one week later. A box full of cut out wires, pile of connectors, trash can full of tape and wire loom, 6 rolls of new tape and 3 panic calls to Lonny (only to find out I didn’t cut out the wrong wire) my harness is finished.
I’m about to order my control arms. What is the measurement you are talking about?ZZP makes it easy to get the right ones they sell both the 19.5mm and 20.5mm the LNF uses. I had to return 2 different sets from rock auto that "Said" they are for an SS/TC 2009 car but both ended up being the smaller 19.5mm
Nuker-
The ball joint that connects at the bottom of the knuckle. The SS/TC uses the 20.5mm shaft on the ball joint vs all others using the 19.5mmI’m about to order my control arms. What is the measurement you are talking about?
This is the factory mount on the SS/SC. If it's different on the turbo, I apologize for the confusion.I have the same question. Does anyone have a pic on where it gets mounted?
Thanks!
Thank you. I did order the TC kit so I’ll have to look for the pumpDonor is a 2009 SS/TC which does not come with the pump. When you ordered your kit, if the TC donor option was selected, then DF should supply the pump for the heat exchanger and the large clamp to mount it.
I am SO glad that Lonny was able to confirm you did not cut the wrong wire. When we spoke on the phone about it, I knew you were wondering!Well one week later. A box full of cut out wires, pile of connectors, trash can full of tape and wire loom, 6 rolls of new tape and 3 panic calls to Lonny (only to find out I didn’t cut out the wrong wire) my harness is finished.
That man is amazing.I am SO glad that Lonny was able to confirm you did not cut the wrong wire. When we spoke on the phone about it, I knew you were wondering!
Man! That's a good turn around. I took mine in on Friday and they told me a week maybe two..... I betting on the two.Well looks like Friday is the start of assembly.View attachment 21342
