ATMironov
Whoops, so it was.. I jumped the gun there a bit.My answer was to the intercooler leak, not brakes. Brakes should never have any sealer of any type, anywhere.
For the brakes I did loosen and crank it back down. The seeping is 95% gone. One last connection in the morning. The Teflon question was about the heat exchanger leaks. Thanks for you concern thoughAre you sure? Brake fluid is very corrosive. I don't know if that's a good long term fix. Plus if not wrapped well, the tape could interfere with the tapered seat and make the problem worse.
My vote is to follow Lonny's directions above
Used this to bleed the fluid from the brakes during disassembly. Worked like a charm.If you own a compressor and need to bleed a new brake system and clutch. Do yourself a favor and get one of these. https://www.harborfreight.com/brake-fluid-bleeder-92924.html. Your quads will thank you later
Thank you ArkCheck this post.
Is the check valve necessary? If so, should it allow flow only from the valve cover to the intake?Check this post.
There is a check valve there from the factory, so I put a check valve in there in my build. Obviously, so did @JBINTX ... whether it's necessary or not, I cannot say.Is the check valve necessary? If so, should it allow flow only from the valve cover to the intake?
Man those look sweet!Got my seats today. The passenger (of course) went together flawlessly. The driver when a bolt was about 3/4 of the way in it stopped and snapped. It was not cross threaded I was being super careful. I think I had a faulty bolt. Then when trying to drill it out to retap it the bit snapped. Not I’m at a loss.
On a side not I ordered planted tech seat brackets. Came up with a clever design. Instead of putting flat stock in to take up the 1/2” gap I drilled and taped 2 holes then ran a bolt from the bottom up to apply tension.
I think that’s the best looking seats that I have seen ! Top notchGot my seats today. The passenger (of course) went together flawlessly. The driver when a bolt was about 3/4 of the way in it stopped and snapped. It was not cross threaded I was being super careful. I think I had a faulty bolt. Then when trying to drill it out to retap it the bit snapped. Not I’m at a loss.
I may have to buy another set. I can not extract the broken bolt or drill bit and welding is not an option.I think that’s the best looking seats that I have seen ! Top notch
