PyroGuy923
Finally got mine installed.
If your left to right attachment is in the bottom hole, move it up to the top hole. That will lengthen your left to right throw and put a little bit more space between first to third and third to fifth. That is about all of the adjustment in the shifter itself. If you could get enough throw, you could possibly put one more hole up above the top one but you may run into some interference problems.I got my shifter installed some time ago, and so far it's been mostly positive. I'm still waiting on stupid Missouri to send my title, so i've only driven a couple of times (on closed roads only, officer, I swear!)
The one issue I have is 3rd and 5th gear are just next to each other. I mean, It's almost impossible for me to tell the difference between them. 3rd is straight up from where the shifter rests naturally, so it's easy to hit. But 5th....you just nudge it ever so slightly right, and that's it. You can't go too far right, or you hit no-mans-land and can't get it into gear at all.
Is there any sort of adjustment to get 3rd and 5th to separate a little more from left to right? The car is really difficult to drive as it is, and I have money-shifted a few times from 4th to 3rd, luckily never under power or high RPM. The potential for disaster is there though.
Keep in mind, the trans has 140k on it, and has probably not had an easy life. It's possible some shift forks are bent, and that's what causing the trouble. But if I can adjust it out with the shifter, that would be preferable to a trans rebuild.
Darn it @Lonny. Just when I think I'm getting finished with projects.We now have upgraded bellcranks with double ball bearings that will be added to the store in the next few days.
I too will buy a set!We now have upgraded bellcranks with double ball bearings that will be added to the store in the next few days.
Were you able to fix the issue with the new shifter going from 3rd to 5th? Same thing happens to me some of the timeI got my shifter installed some time ago, and so far it's been mostly positive. I'm still waiting on stupid Missouri to send my title, so i've only driven a couple of times (on closed roads only, officer, I swear!)
Sorry, I meant 4th to 5th. Crazy morningWere you able to fix the issue with the new shifter going from 3rd to 5th? Same thing happens to me some of the time
Sorry, I don't have any new info yet. It got cold here in Missouri, and I haven't really had a chance to drive it or even mess with it.Were you able to fix the issue with the new shifter going from 3rd to 5th? Same thing happens to me some of the time
Sounds goodSorry, I don't have any new info yet. It got cold here in Missouri, and I haven't really had a chance to drive it or even mess with it.
I'll try to get an update this weekend.
Did you ever fix your shifting issue from 4th to 5th?I got my shifter installed some time ago, and so far it's been mostly positive. I'm still waiting on stupid Missouri to send my title, so i've only driven a couple of times (on closed roads only, officer, I swear!)
Thanks for the follow-up. I'm sending the Goblin to ZZP next month for a Turbo upgrade and I'll ask them about itI did not.
I basically am just getting used to it. After putting a few more miles on the car, I have just learned to be cautious on the 4-5 shift. Gears 1 through 4 are the only ones that are hurried anyway. On a race track, I doubt 5th is used much, if at all. With a little practice, I don't think it will be an issue.
The other reason I haven't fixed it is just laziness. It's been cold here, and I haven't really had a chance to drive the car very much. So, it's a project waiting for spring.
I'm not sure it can be fixed at all, anyway. I have already monkeyed with the shifter to get the maximum lateral throw out of it, so there isn't anything else that can be adjusted on the shifter side. I worry it's just a function of my current transmission. Perhaps it's difficult for all of them, or perhaps the kid before me bent the shift forks on the donor, and now it doesn't quite work like it did before. I'm not sure.
I have a brand new transmission and have no problems, other than how close 3rd and 5th are combined with the extra left to right movement there is to get to reverse. If you miss the slot for 5th you end up in “No Shifting” land at the top of the reverse gate. Once there, I had to go back into 4th and then try to hit 5th again.I did not.
