Did you have any play on your pressure plate and the guide pins because that's what the pen is for because lots of people where saying that if it's not dead center it creates a little vibration that way they came up with that I'm just passing the info I hate to see you guys have to pull everything out again because of the vibrationsI did not need those spacers but you will want the clutch alignment tool. It was pretty straight forward, I'd replace the TOB and pipe while in there. The upgraded tob feels good.
Nuker
I believe it does and I've got my bic pen chopped up already.Not sure if it applies to the S/C
Do the axles just pop out? I couldn't get them to pop with two pry bars and didn't want to force it.I did not need those spacers but you will want the clutch alignment tool. It was pretty straight forward, I'd replace the TOB and pipe while in there. The upgraded tob feels good.
Nuker
Yes they do I used a Crowbar little by little side by sideDo the axles just pop out? I couldn't get them to pop with two pry bars and didn't want to force it.
Yes sir, the kit comes with the upgraded TOB, I bought a new pipe and elbow just because I'm in there.You do have a clutch alignment tool right?
Hope your replacing the TOB also the upgraded LSJ aka LNF is a big upgrade.
Nuker
