Vwsaabvt
Is the brake fluid leaking from the fitting at the threads or where the hose is attached to it? A few of us just skipped the kit parts and went with upgraded linesSo some good and bad so far…
The pros are that the intercooler setup is all on and hopefully all the leaks have been fixed. The firewall is also finally in since I won’t have to reach back there too much hopefully
The cons are that the relocation block is leaking brake fluid from the brass fittings and they cannot be tightened at all to try to counter it short term. I’ll also need to contact DF to get a different set of seat brackets because I’m running two different sizes seats. All fixable stuff but not going to be driveable I’m afraid.
If anyone knows a solution to the fittings whether it’s Loctite or anything like that feel free to share
