Hey does anyone know what I need to do to my 2006 supercharge motor before I install it in the kit body. I watch the build video but it’s not a supercharged model. Besides the AC. What else should I eliminate from the harness or the motor?
I don't remember eliminating much from my 2006 SC donor. Just these 2 little things:
- The vacuum hoses on the top, and a solenoid.
- removed the extra fan wire & connector that use to go to the radiator.
I bought the DF solid mounts for the engine, as the transmission mounts were solid, it didn't make sense to have rubber engine mounts.
Also an 06 SS SC here. Things I removed: evap canister (wires plugs are still there), aluminum tape over the AC condenser ports, 1 plug is unused from the AC condenser area but I just left it and covered it. I covered the other radiator fan plugs, didn't remove.
